What is the AI Chatbot?
AI Chatbot is the conversational intelligence hub of the Visual Paradigm Ecosystem. It acts as an interactive co-pilot that bridges natural language instructions with architectural modeling, knowledge analysis, and multi-app workflow pipelines.
Instead of manually searching for tools or drawing components shape by shape, you can converse with the AI to generate diagrams, synthesize unstructured notes, and seamlessly push artifacts across the entire Visual Paradigm suite.
1. Conversational Diagram Ideation
The AI Chatbot allows you to generate and refine technical diagrams purely through natural language conversations, whether starting from scratch or from visual source material.
General Usage: Conversational Prompting & Iteration
Instead of manually constructing diagrams or specifications from scratch, you can collaborate with the chatbot naturally. For instance, following an evaluation workflow like our ATM System case study:
- Submit Prompt: Send an initial request, such as asking the AI to “Generate a simple use case diagram for an ATM System”.
- Review Initial Generation: The assistant renders the requested diagram directly in PlantUML syntax within the chat interface.
- Follow-Up Request: Issue a follow-up prompt to drill deeper into specific features, such as asking to “Draft a Use Case Description for the Withdraw Cash use case”.
- Examine Structured Specifications: The AI responds with detailed tabular documentation covering triggers, preconditions, main success scenarios, alternative flows, and special requirements.
- Elaborate & Refine: Continue the conversation by requesting architectural variations, such as asking to “Generate a MVC sequence diagram for the happy path” to translate your requirements into dynamic interaction models.
- Let’s say you are happy with the generated diagram and want to keep it for further refinement later on. You may click on Send to Pipeline and retrieve the diagram in VPasCode, Visual Paradigm Online and Visual Paradigm Desktop. For more details, please read the section about extended workflows below.
Starting with an Uploaded Image (Visual-to-Model)
You aren’t limited to text prompts. You can feed hand-drawn sketches or whiteboard photos directly into the chatbot conversation.
To get the most value from image upload, treat the uploaded diagram as the starting point of a conversation. First, ask the AI Diagramming Chatbot to analyze and describe what it sees. After confirming that the chatbot understands the model, ask it to extend the model or generate a more detailed diagram. Let’s walk through the steps with an ERD example. We will start with this ERD:
You can download this draft ERD here: Download Draft ERD
- Upload your image.At the bottom of the AI Diagramming Chatbot, drag your image into the message box. You can also click the attachment icon to select an image file, or press
Ctrl-Vto paste an image copied to your clipboard.
- Ask the chatbot to identify and describe the model.Submit a message that asks the AI to inspect the uploaded image and explain what it contains. For example:
“Analyze the attached ERD. Identify all domain entities and describe the relationships between them. Do not add fields yet.”
This first step allows you to check whether the chatbot has correctly understood the visual model. It can identify the entities, relationships, and overall business context represented in the image.
- Review the chatbot’s interpretation.Read the response and check whether the identified entities and relationships match the original image. If necessary, correct or clarify the model through a follow-up message.
- Ask the chatbot to develop the model further.Once the chatbot has correctly understood the image, ask it to add the level of detail you need. For example, you can ask it to transform the conceptual model into a physical ERD by adding database columns, data types, primary keys, and foreign keys:
“Based on your understanding of the attached ERD, generate a physical ERD. Add suitable database columns, data types, primary keys, foreign keys, and constraints for each entity.”
- Review Chatbot’s answer.
Your question would be processed and answered. In this case, a physical ERD is formed. As per the request, AI produces a relational database design. It not only added the database columns to all domain entities, but also added an additional entity OrderLine to resolve the many-to-many (N:M) relationship between Order and Product.
2. AI Knowledge Analysis
To evaluate how the AI Chatbot handles complex project data, we will use the sample knowledge base prepared in NotesKeep.
If you haven’t reviewed the NotesKeep guide yet, here is a quick background:
Background & Pre-Prepared Sample Data:
In your Playground workspace, we have prepared three key artifacts representing requirements gathered at different stages of the ATM System project:
ATM Requirements: From Operations Team(Dated Oct 10): Initial operational notes outlining customer features, cash alerts, and manual on-site maintenance.
ATM Requirements: Security & Compliance Review(Dated Oct 26): Updated requirements from a later security review, introducing stricter controls and modified workflows.
ATM Withdraw Cash flowchart: A photo of a whiteboard diagram captured during an early business analyst kickoff session.
What Makes This Special (Real-World Conflicts & Chronology):
Software requirements evolve over time and frequently contain conflicting instructions. For instance, the Oct 10 operations note states that software updates are performed manually on-site, whereas the Oct 26 security note dictates remote updates. Similarly, cash deposit features and receipt printing rules differ between the two dates. This chronological, conflicting dataset is designed to test whether the AI can look across multiple notes, recognize timeline precedence, detect contradictions, and synthesize a single unified source of truth.
Step-by-Step AI Knowledge Examination Guide
Instead of doing a generic search, you will scope your query directly to your project repository so the AI references your notes accurately.
- Open the AI Chatbot panel within your Playground workspace.
- At the bottom input area, click on the search scope selector and select Search in NotesKeep.
- Set the project scope dropdown to ATM System.
- Set the knowledge scope dropdown to Any Knowledge so the AI can scan all available notes and uploaded documents.
Phase 1: General Context & Search (Warm-up)
Execute these prompts to verify that the AI has successfully ingested and understood your notes rather than just performing superficial keyword lookups:
- Prompt 1:
What did the Operations team say about printing receipts?
Expected Answer: It quotes the Oct 10 note, stating that receipts are required for withdrawals but optional for balance inquiries. - Prompt 2:
Are there any hardware or software constraints mentioned?
Expected Answer: It points out the manual on-site software updates from Oct 10, and the deferred deposit feature due to hardware limitations from Oct 26.
Phase 2: Consolidation & Conflict Detection (The “Wow” Moment)
Test the AI’s advanced capability to synthesize chronological, conflicting records:
- Prompt 1:
Compare the two requirement notes. What are the main conflicts or changes between them?
Expected Answer: It lists the Deposit feature (included vs. deferred), the Receipt policy (optional vs. mandatory), the Low Cash alert (screen vs. API), and the Software update method (manual vs. remote). - Prompt 2:
Create a consolidated list of requirements. For any conflicting points, assume the newer Security & Compliance note (Oct 26) takes precedence.
Expected Answer: It generates a single, unified list where receipts apply to all transactions, updates are remote, and deposits are deferred. - Prompt 3:
Based on the Oct 26 note, what happens if a customer enters the wrong PIN three times?
Expected Answer: It specifies that the card will be retained by the ATM based on the newer security rules.
Phase 3: Document Generation (Final Output)
Turn raw notes into a formal project deliverable:
- Prompt 1:
Draft a formal 'Project Scope & Conflict Resolution' document based on these notes. Format it with an Executive Summary and a table comparing the old vs. new requirements.
Expected Result: The AI produces complete, structured document text complete with a markdown comparison table ready to export. - Prompt 2:
What are the next steps or Phase 2 items based on this notes collection?
Expected Result: The AI explicitly lists Cash Deposit capability and hardware upgrades under Phase 2.
3. Extended Workflows: From Ideation to Multi-App Execution
Once you generate a diagram through conversational AI, you can transition it directly into specialized editing or documentation environments using two primary integration pathways.
Ideation to Diagram Editing
Workflow A: Ideation to VP Online (Visual Drag-and-Drop Touchup)
If you prefer adjusting shapes visually rather than writing syntax or chatting:
- Send an initial request, such as asking the AI to “Generate a simple use case diagram for an ATM System”.
- Once the AI generates your diagram, click the button Edit in VP Online at the bottom right to open or edit it in VP Online.
- This automatically launches the visual drag-and-drop diagram editor.
- Reposition shapes, add connecting lines, adjust formatting, and save your changes back to the project repository.
Workflow B: Edit with VPasCode (Immediate Edit vs. Pipeline Staging)
If your AI-generated diagram needs code-level refinement, you can open it directly in VPasCode, or stage it for later.
Method 1: Direct Editing
Generate a UML State Diagram for an ATM. Click on Edit in VPasCode at the bottom right to open it directly in VPasCode, where you can modify its PlantUML text syntax on the fly in the code editor.
Method 2: Staging via Pipeline
If you are in the middle of a brainstorming session and don’t want to break your conversational flow, you can stage diagrams using the pipeline feature:
- Generate a simple use case diagram for an ATM System.
- Once the AI generates the use case diagram, click Send to Pipeline at the bottom right of the diagram viewer to keep the diagram in the pipeline. Optionally, give it a name and click Confirm.
- Submit the next prompt: ‘Draft a Use Case Description for the Withdraw Cash use case’.
- The AI will generate a Use Case Description.
- Submit the next prompt: ‘Generate a MVC sequence diagram for the happy path’.
- The AI will generate a Sequence Diagram. Again, keep it in the Pipeline.
- To retrieve your items, go to OpenDocs or click on the Home icon on the left of the app bar to go to the Unified Platform. From there, open VPasCode.
- In VPasCode, click on the Pipeline button on the app bar.
- From the popup dialog, you can see the diagrams sent from the chatbot. Click to open any of them and start editing in VPasCode’s diagrams-as-code editor.
Ideation to Composing Document
Workflow C: Ideation to Technical Documentation (OpenDocs Integration)
To incorporate your AI-generated diagram into formal project documentation via our shared central memory pipeline, follow these steps:
- Generate a Class Diagram with the prompt “Generate a simple domain Class Model for an ATM System“.
- At the bottom right of a class diagram generated, click Send to Pipeline to store your generated diagram in your active session memory. You can leave the optional name prompt default and click Confirm.
- Open OpenDocs by first clicking on the home icon on the left of the app bar to visit the Unified Platform. From there, select to open the app OpenDocs.
- In OpenDocs, a space acts as a site holding related pages or a sub-project. The Playground workspace includes a pre-prepared sample space. Make sure you are opening the space ATM System Architecture Hub. If not, click on the drop-down menu showing the space name at the top left corner and select Load Space. Then, select the pre-configured sample space: ATM System Architecture Hub.
- Review the table of contents (TOC) on the left sidebar. Open the target page where the diagram should live – navigate to page 2.1 Domain Model.
- Locate the placeholder text [PLAYGROUND INSTRUCTION: Embed a Class Diagram] on the page where you are required to insert the diagram, and place your cursor there.
- Click on the Pipeline button at the top right corner of OpenDocs to toggle open the Pipeline drawer.
- Locate the diagram you just sent from the AI Chatbot session inside the Pipeline panel, and click on it. The diagram will instantly be embedded into your OpenDocs page.
- Click Save at the top right to commit your documentation changes. You can then publish or share your page or space accordingly.
Table of Contents
