What is OpenDocs?
OpenDocs is the modern documentation and knowledge-sharing application within the Visual Paradigm Ecosystem. It allows teams to build structured, wiki-like spaces, technical specifications, and user guides that are dynamically linked to live architectural models, flowcharts, and diagrams. Overview of the Pre-Loaded ATM Space: To help you evaluate OpenDocs immediately, your Playground workspace includes a fully structured sample space titled “ATM System Architecture Hub”. This space mirrors a real-world software architecture documentation site, organized into intuitive folders:
  • Folder 1: Business Analysis & Requirements (Project overview, user stories)
  • Folder 2: System Architecture & Design (Domain models, ERDs, sequence diagrams)
  • Folder 3: Process Flows & Logic (Authentication flows, cash management, transaction logs)
  • Folder 4: Deployment & Infrastructure (Deployment diagrams, non-functional requirements)
  • Folder 5: Appendices & Reference (Configured as a clean, tabbed UI showcasing glossaries, security policies, and release notes)
Core Document Operations: Creating, Editing & Saving
Before embedding interactive diagrams, let’s walk through a hands-on guide to mastering the foundational document operations in OpenDocs:
Step 1: Creating a New Page
  1. Navigate to your OpenDocs space in the sidebar navigation.
  2. Hover over your target folder (for instance, Folder 1: Business Analysis & Requirements) and click the + icon that appears next to it.
  3. Select New Document Page from the popup context menu. This creates a new page.|
    Type the page title: ATM Testing Procedures.
Step 2: Editing Page Content
  1. Click anywhere inside the main text area of your newly created page.
  2. Type a short introductory sentence: This document outlines the testing protocols for the ATM System release.
  3. Press Enter to start a new line, select Bullet List in the tool bar, and add a few sample checklist items (e.g., Verify card reader sensor, Test PIN retry lockouts).
Step 3: Saving Your Changes
  1. Click the Save button located at the top right corner of the document editor toolbar to finalize your updates to the space repository.
Inserting a VPasCode Diagram Directly into a Page
OpenDocs allows you to build text-to-code diagrams inline without leaving your documentation environment, ensuring code and documentation remain synchronized.
  1. In the left sidebar TOC, open the page named ‘2.3 Sequence Diagram: Withdraw Cash’.
  2. Scroll down to section ‘2. UML Sequence Diagram’. Locate the red placeholder text [PLAYGROUND INSTRUCTION: Insert a Sequence Diagram Here], click right after it, and press Enter to add a new line.
  3. Click on the + (Insert block) button in the editor toolbar.
  4. This opens the Create an Artifact window. On the left menu, select the VPasCode category.
  5. Select VPasCode on the right pane.
    This launches the embedded VPasCode editor directly inside your document workflow.
  6. Copy and paste the following PlantUML script into the left-hand code editor:
    @startuml
    !theme plain
    skinparam sequenceMessageAlign center
    skinparam responseMessageBelowArrow true
    autonumber
    actor "Customer" as cust
    participant "ATMScreen\n(View)" as ui
    participant "ATMController\n(Controller)" as ctrl
    participant "Account\n(Model)" as acc
    participant "CashCassette\n(Model)" as cash
    participant "BankServer\n(External)" as bank
    participant "ReceiptPrinter\n(View)" as printer
    == 1. Session Initialization & Authentication ==
    cust -> ui : Insert Card
    ui -> ctrl : readCard(cardNumber)
    ctrl -> bank : verifyCustomerCard(cardNumber, PIN)
    note right of bank : Validates credentials
    bank --> ctrl : Auth Success (Token)
    ctrl -> ui : showMenu()
    == 2. Withdrawal Request ==
    cust -> ui : Select "Withdraw Cash"
    ui -> cust : requestAmount()
    cust -> ui : Enter $100
    ui -> ctrl : withdraw(100.0)
    == 3. Internal Validation & Processing ==
    ctrl -> acc : getBalance()
    acc --> ctrl : return balance (e.g., $500)
    ctrl -> ctrl : checkSufficientFunds(100.0)
    alt [Funds Sufficient]
        ctrl -> bank : processTransaction(Transaction)
        note right of bank : Debits account in core ledger
        bank --> ctrl : Transaction Approved
        ctrl -> acc : updateBalance(-100.0)
        ctrl -> cash : dispense(100.0)
        cash --> ctrl : Cash Dispensed
        ctrl -> printer : print(Transaction)
        printer --> ctrl : Receipt Printed
        ctrl -> bank : logTransaction(Transaction)
        ctrl -> ui : displayMessage("Please take your cash")
    else [Insufficient Funds]
        ctrl -> ui : displayMessage("Insufficient Funds")
    end
    == 4. Session Termination ==
    ctrl -> ui : Eject Card
    @enduml
  7. Observe the rendered sequence diagram update live on the right preview pane. Click Save at the top right.
  8. Click Close to return to your OpenDocs page, where the sequence diagram is now embedded seamlessly.
Inserting a Visual Paradigm Online Diagram
While VPasCode uses text syntax, VP Online provides a traditional visual drag-and-drop editor for architectural modeling.
  1. Open the page named ‘4.1 System Deployment’ in your left sidebar.
  2. Under section ‘2. UML Deployment Diagram’, find the red instruction text [PLAYGROUND INSTRUCTION: Insert Deployment Diagram Here], add a new line below it, and click the + insert button.
  3. From the left menu of the popup window, select the Diagram category.
  4. Select Deployment Diagram on the right. This launches the VP Online visual editor.
  5. From the shape palette on the left sidebar, select the Node shape and drag it onto the canvas. Repeat this to create three distinct nodes: ATM Terminal, Bank Data Center, and Cash Management System.
  6. Connect ATM Terminal to Bank Data Center using a connector line labeled Secure Network (VPN), and connect ATM Terminal to Cash Management System labeled Low Cash Alerts.
  7. *(Since our focus is on OpenDocs publishing rather than full architecture drawing, we will stop here).* Click Save at the top right.
  8. Click Close to exit the editor and return back to your OpenDocs page.
Organizing Pages into Tabbed Folders
To keep documentation clean and prevent endless scrolling, OpenDocs supports Tabbed Folders. This allows a parent folder to act as a container where child pages are automatically rendered as sleek, clickable tabs (ideal for reference guides, glossaries, and changelogs). You can explore Folder 5 (“Appendices & Reference”) in your pre-loaded workspace to see a live demonstration containing tabs for Glossary of Terms, Compliance & Security Policy, and Release Notes.
Steps to Create a Tabbed Folder Space
  1. In your OpenDocs space navigation panel on the left, click the + button next to the space and select New Tabbed Folder to create a new folder.
  2. Name the folder Project Governance & Stakeholders and click Confirm.
  3. Now, edit the three child pages directly nested under this folder: name them Executive Committee, Escalation Matrix, and Meeting Cadence.
  4. When you click on the parent folder in OpenDocs, the child pages will now automatically render as interactive horizontal tabs across the top of the reading pane rather than nested tree items.
Sharing Pages and Spaces
Once your documentation is ready, OpenDocs provides flexible sharing controls to collaborate seamlessly with your stakeholders:
  1. Click the Share button located at the top right of the application interface to initiate the secure link generation process for external reviewers or team members. Clicking the Share button in OpenDocs
  2. Select the specific pages or folders you wish to include in your shared bundle.
    Selecting pages to include in the share
  3. Click Next on the app bar to proceed to the generation settings.
  4. Click Generate Link inside the Share Space dialog box to finalize permissions.
    Generating the share link
  5. Copy the generated URL and distribute it to your colleagues. They can instantly access your shared documentation space by opening the link in their web browser.
    Copying the shared URL
Extended Workflows: Document Diagrams to Living System Pages
One of the most powerful features of the Visual Paradigm Ecosystem is the ability to bridge creation tools with professional publishing pipelines—turning standalone technical diagrams into maintained, cross-app reference documentation.
The Pipeline Concept: Instead of exporting image files locally and uploading them manually, you can create diagrams in any ecosystem app (VP Online, VP Desktop, AI Chatbot, or VPasCode), send them to your session Pipeline, and instantly embed them into OpenDocs.
Retrieving Staged Diagrams from the Pipeline
Assuming you have already generated a diagram (for example, an Activity Diagram from VPasCode or the AI Chatbot) and clicked *Send to Pipeline*:
  1. Open the page named ‘3.3 Transaction Log Process’ in OpenDocs.
  2. Under section ‘2. Activity Diagram (Transaction Logging Flow)’, add a new line below the red instruction text [PLAYGROUND INSTRUCTION: Insert an Activity Diagram Here].
  3. Click on the Pipeline button in the top header toolbar to open the Pipeline data drawer.
  4. Locate your staged activity diagram (“Transaction Log Process”) inside the panel.
  5. Click on the diagram thumbnail to embed it directly into your OpenDocs page.
  6. Click Save. Your documentation is now dynamically linked to your evolving modeling pipeline. *(For detailed end-to-end instructions on generating diagrams via VPasCode or AI Chatbot prior to pipeline transfer, refer to their respective evaluation guides).*
